🎉Community Raffle - Win $25
Join and Win
How to create a 'real' random value?
User: "kayman"
New Altair Community Member
Updated by Jocelyn
Probably overlooking something but I am struggling to get a random record that is actually changing each time. There is the option to get a random sample value, but this always gives me the same one, and same goes for generating a random value using the rand() function. Also here I get the same random number each time, while I want a new one instead.
I simply want to get a single random record out of a recordset, but it should be a different record each time I call the set.
Any ideas?
1 - 2 of 21
    User: "YYH"
    Accepted Answer
    Hi @kayman,
    You are correct. There is no real random value in computer science... Maybe you have already heard Pseudorandom number.
    “On a completely deterministic machine you can't generate anything you could really call a random sequence of numbers,” says Ward, “because the machine is following the same algorithm to generate them. Typically, that means it starts with a common 'seed' number and then follows a pattern.”
    https://www.howtogeek.com/183051/htg-explains-how-computers-generate-random-numbers/
    https://engineering.mit.edu/engage/ask-an-engineer/can-a-computer-generate-a-truly-random-number/
    For a more day-to-day example, the computer could rely on atmospheric noise or simply use the exact time you press keys on your keyboard as a source of unpredictable data, or entropy. For example, your computer might notice that you pressed a key at exactly 0.23423523 seconds after 2 p.m.
    That is similar to how we use the date_now() or the process_start timestamp to generate the rand seed for a random number.
    <?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
        <parameter key="random_seed" value="1992"/>
        <process expanded="true">
          <operator activated="true" class="generate_macro" compatibility="9.2.001" expanded="true" height="68" name="Generate Macro" width="90" x="112" y="34">
              <parameter key="seed" value="mod(date_millis(date_now()),10000)"/>
              <parameter key="Pseudorandom_num" value="rand(round(eval(%{seed})))"/>
            </list>
          <operator activated="true" class="generate_data" compatibility="9.2.001" expanded="true" height="68" name="Generate Data" width="90" x="514" y="34">
            <parameter key="target_function" value="random"/>
            <parameter key="number_examples" value="1"/>
            <parameter key="number_of_attributes" value="1"/>
            <parameter key="attributes_lower_bound" value="-10.0"/>
            <parameter key="attributes_upper_bound" value="10.0"/>
            <parameter key="gaussian_standard_deviation" value="10.0"/>
            <parameter key="largest_radius" value="10.0"/>
            <parameter key="use_local_random_seed" value="true"/>
            <parameter key="local_random_seed" value="%{seed}"/>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          <connect from_op="Generate Data" from_port="output" to_port="result 1"/>
        </process>
    </process>
    User: "MartinLiebig"
    Accepted Answer
    Hi @kayman ,
    try to set the random seed of the main process to -1, this will set the seed to something which is connected to the system time. Thus you get different numbers each time you run it.
    Best,
    Martin
