<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="1992"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="9.2.001" expanded="true" height="68" name="Generate Macro" width="90" x="112" y="34"> <list key="function_descriptions"> <parameter key="seed" value="mod(date_millis(date_now()),10000)"/> <parameter key="Pseudorandom_num" value="rand(round(eval(%{seed})))"/> </list> </operator> <operator activated="true" class="generate_data" compatibility="9.2.001" expanded="true" height="68" name="Generate Data" width="90" x="514" y="34"> <parameter key="target_function" value="random"/> <parameter key="number_examples" value="1"/> <parameter key="number_of_attributes" value="1"/> <parameter key="attributes_lower_bound" value="-10.0"/> <parameter key="attributes_upper_bound" value="10.0"/> <parameter key="gaussian_standard_deviation" value="10.0"/> <parameter key="largest_radius" value="10.0"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="%{seed}"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <connect from_op="Generate Data" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
