GUI Problem
Hi All,
I facing Issue in three widgets :
1) Change the font of Inputs Dialogue in TK (e.g CAMBRIA , 14)
2) How to assign the values of a dynamically created Entry Box to a list using TCL.
3) How to assign the procedure to the buttons in Dialogue. (OK , APPLY and CANCEL on the dialogue Box situated at the bottom)
please help me to clarify these doubts.
Best Regards,
Dhairyasheel Desai
Hi Livil,
Thanks for the Reply. It was very Helpful. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
1 ) My question was about font of INPUT DIALOG
font create myFont -family cambria -size 14
'set myanswer [hwtk::inputdialog -title 'Material' -text 'Enter Material Name' -font myFont'.
2) About Assigning the Procedure to the Default Buttons on the Dialogue Box (OK , CANCEL, APPLY) Please refer to the Images attached.
Thanks in Advance
Best Regards,
Dhairyasheel
Tata Technologies
.dialog buttonconfigure ok -command {}
Thanks Pandurang..!! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Hi Dhairyasheel,
1. first create a font with the properties and then assign it to the label you create
font create myFont -family cambria -size 14 ttk::label .test.frame1.label1 -text 'Hello' -font myFont -width 15
2. all entry boxes have a variable set using -textvariable which should be a namespace variable, this can be set dynamically and will be reflected accordingly.
hwtk::entry frame_1.ent_1 -textvariable ::mynamespace::entry1variable
3. use -command followed by the function while creating the button:
hwtk::button frame_1.button_1 -text 'test' -command {::test::Myprocedure}
