Problems with Solid Edit Using Sweep Lines
I am having a few issues I was hoping someone could be of help with. When using the Solid Edit with sweep lines command I am running into a problem where when I get to the smaller sections I need to cut, the program will not cut these sections. I am getting an 'internal error'. '
I am also getting a weird effect where a random geometry begins protruding from the model. I have no clue what could be causing this problem.
I have tried adjusting the node tol, cleanup tol and element size but haven't had any luck.
Screenshot 1 is Solid Selection
Screenshot 2 is Line Selection
Screenshot 3 is Protruding Geometry
Thank you,
-Clay
<?xml version="1.0" encoding="UTF-8"?>![]()
Sorry, thought this might be a common problem with an easy fix.
This information was taken from the Updates and System Information page:
This is the method I am currently using with the Y-Axis as the vector direction
Hi Cer54,
I mean to say, create a vector based on end nodes and use the solid edit option.
You can create a vector using Vectors panel (Analysis page>> Vectors)
Hi Cer54,
I defined the vectors using nodes and continue to get an internal error. I just don't understand what could be going wrong
Hi Cer54,
This method seems to have worked when I set the geom tol to 1x10^-8
Important informations when you report a 'bug' are version number, update, OS, ....
