Altair RISE
Nominate Yourself Now!
Problems with Solid Edit Using Sweep Lines
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am having a few issues I was hoping someone could be of help with. When using the Solid Edit with sweep lines command I am running into a problem where when I get to the smaller sections I need to cut, the program will not cut these sections. I am getting an 'internal error'. '
I am also getting a weird effect where a random geometry begins protruding from the model. I have no clue what could be causing this problem.
I have tried adjusting the node tol, cleanup tol and element size but haven't had any luck.
Screenshot 1 is Solid Selection
Screenshot 2 is Line Selection
Screenshot 3 is Protruding Geometry
Thank you,
-Clay
<?xml version="1.0" encoding="UTF-8"?>post-36212-0-62016300-1427390918_thumb.p
<?xml version="1.0" encoding="UTF-8"?>post-36212-0-87007900-1427390919_thumb.p
<?xml version="1.0" encoding="UTF-8"?>post-36212-0-99917700-1427390920_thumb.p
1 - 7 of 71
    Altair Employee
    OP
    Important informations when you report a 'bug' are version number, update, OS, ....
    Altair Employee
    OP
    Sorry, thought this might be a common problem with an easy fix.
    This information was taken from the Updates and System Information page:
     Altair Home: D:/Program Files/Altair/12.0
     Updates Information:
    acusolve12.0.310
    hwdesktop12.0.110
    hwdesktophelp12.0.110
    hwsolvers12.0.210
    hwsolvershelp12.0.210
    SimLab12.2_hw12.0
    sT9.5_hw12.0
    vwt12.0_hw12.0
     Versions:
    hgtrans.exe:                  12.0.110.40 (Mar 25 2014)
    hmopengl.exe:                 12.0.110.40 (Mar 25 2014)
    hst_ng.exe:                   12.0.110.40.500186 (Mar 25 2014)
    hstbatch_ng.exe:              12.0.110.40.500186 (Mar 25 2014)
    hstdss.exe:                   12.0.110.40.500186 (Mar 25 2014)
    hvp.exe:                      12.0.110.40 (Mar 25 2014)
    hw.exe:                       12.0.110.40 (Mar 25 2014)
    hwmbdmodel.dll:               12.0.110.40 (Mar 25 2014)
    hwplot.dll:                   12.0.110.40 (Mar 25 2014)
    hwplot3d.dll:                 12.0.110.40 (Mar 25 2014)
    hwpost.dll:                   12.0.110.40 (Mar 25 2014)
    hwtext.dll:                   12.0.110.40 (Mar 25 2014)
    hwvideo.dll:                  12.0.110.40 (Mar 25 2014)
    hwx.exe:                      12.0.110.40 (Mar 25 2014)
    templex.exe:                  12.0.110.40 (Mar 25 2014)
     System Information:
    Machine:                      amd64
    OS:                           windows Windows NT 6.2
    User:                         Clayton
     Hardware:
    Processor:                     Intel® Core i7-3610QM CPU @ 2.30GHz (8 CPUs), ~2.3GHz
    System Manufacturer:           ASUSTeK COMPUTER INC.
    System Model:                  G55VW
    Total Physical Memory:         12288MB RAM
     Operating System:
    Machine name:                  CLAY-LAPTOP
    Operating System:              Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_r8.150127-1500)
     Graphics/Display/OpenGL:
    Card name:                     NVIDIA GeForce GTX 660M
    Chip type:                     GeForce GTX 660M
    Display Memory:                4033 MB
    Driver Name:                   nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver Version:                9.18.13.4475
    Current Mode:                  1440 x 900 (32 bit) (60Hz)
    Altair Employee
    OP
    HI cer54,
    Can you define a vector and use the vector direction to sweep the lines?
    Altair Employee
    OP
    HI cer54,
    This is the method I am currently using with the Y-Axis as the vector direction
    Altair Employee
    OP
    Hi Cer54,
    I mean to say, create a vector based on end nodes and use the solid edit option.
    You can create a vector using Vectors panel (Analysis page>> Vectors)
    Altair Employee
    OP
    Hi Cer54,
    I defined the vectors using nodes and continue to get an internal error. I just don't understand what could be going wrong
    Altair Employee
    OP
    Hi Cer54,
    This method seems to have worked when I set the geom tol to 1x10^-8
