contacts for abaqus solver using hypermesh
I need help defining the contact between the parts shown in the attached image. The solver is Abaqus. I have given tie constraint between 1st and 2nd part (both master and slave are selected as surface). these two parts should be like glued to each other and no separation between them. but the tie is not working as the 1st part is passing through the other. also, the 1d line element should move with the parts to which it is connected.
thank you
1 - 1 of
11
Hi jyoti
Have a look at the tutorial HM-4320 and HM- 4330 from online help.
