Auto closing hm session
vipin_22401
vipin_22401 Altair Community Member
edited August 2023 in Community Q&A
I want to terminate the hm session if it is idle for more than one hour.
Is there any option available inside the license file? Or else what is the alternative?
Welcome!
Answers
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited March 2018
    License file, I don't know. But with License server, it seams that's possible. I'm not sure.
  • tinh
    tinh Altair Community Member
    edited March 2018
    Hi
    What do you mean 'idle'?
    Suppose that you want to close if over 1h there is no user interaction on hm session:
    Try a proc like this
    proc ::p_MonitorHmSession {TriggerTime TriggerScript} {
             if {[focus] ne ''} {
                     dict set ::p_MonitorHmSession -lastused [clock seconds]
              } else {
                     if {[clock seconds]-[dict get $::p_MonitorHmSession -lastused]>$TriggerTime*3600} {
                              uplevel #0 $TriggerScript
              after cancel [list ::p_MonitorHmSession $TriggerTime $TriggerScript]
              after 5000 [list ::p_MonitorHmSession $TriggerTime $TriggerScript]
    now start the monitor:
    ::p_MonitorHmSession 1 hm_exit; #after 1hour if do not focus on hm window, it will exit
  • vipin_22401
    edited March 2018
    Hi,
    Thanks a lot for the script, this is what i exactly looking for.
    I have added the command to save the file in some location before closing.
  • Roshan Shiveshwar
    Roshan Shiveshwar Altair Community Member
    edited March 2018
    Hi,
    If I run a HM script that runs for more than $TriggerTime hrs and minimize the HM window, will HM get closed ? or will it wait for the script to be completed?
    Regards,
    Roshan
  • tinh
    edited March 2018
    Try it!
    if your script calls to command 'update' then hm will run the monitor proc and may trigger -> close hm
  • vipin_22401
    edited April 2018
    Hi @tinh,
    If I open two or more hypermesh windows(with script in hmcustom.tcl), the script is closing the window which is on top(please see image below).
    After that it is not closing other windows. I am not keeping any focus on the windows.
    Script is working fine if there is only 1 hm session present. But i need to close all the sessions which are not in use. Is there any solution for this?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.cef8697985abf48dd64cb81c5fa46a2d.png
  • tinh
    edited April 2018
    Hi Vipin
    You have to run the script on all hm sessions
    put the script in a file named hmcustom.tcl in folder c:\users\your_account
    hm will run it when opening
  • vipin_22401
    edited April 2018
    Hi tinh,
    Yes I did the same, but after the first window is closed it is not working on other windows. If all windows are minimized it will work.
    Only problem is if i keep windows like the above image it is not working.
  • tinh
    edited April 2018
    I see, it's because when one session was closed, window focus in next one so it seems to get 'interaction' with user.
    minimizing all can avoid this, or open other window on top (eg. notepad)
    or modify script that before exiting then tells other sessions not to get focus
  • Roshan Shiveshwar
    edited April 2018
    Hi,
    If I have to extend this to Hyperview , in which file  should I place this code?
    Thanks,
    Roshan
  • tinh
    edited April 2018
    Hi
    save the codes in any file, example C:\mystartup.tcl
    right click on HV icon and select Properties
    in Target field add arguments:
    -tcl C:\mystartup.tcl
  • Roshan Shiveshwar
    edited April 2018
    Hi,
    For HV 14 ,  I found another way where I can place the code in 'hwstartup.tcl'. This file is available in '.\..\HW14.0\hw\tcl' directory.
    'hwstartup.tcl' gets executed whenever HV gets launched.
    Unfortunately, this tcl file is not available for HV 13 n below.  Any idea what other files I can try with?
    Thanks,
    Roshan
  • tinh
    edited April 2018
    Hi Roshan
    you can put the codes in
    c:/users/your_account/hwinit.tcl
  • Roshan Shiveshwar
    edited April 2018
    Hi tinh,
    I tried with hwinit.tcl . But, I 'm getting this error.  Not sure why?
    UPDATE : I had put the code in  '.\..\HW14.0\hw\tcl\hwinit.tcl'.
  • tinh
    edited April 2018
    Hi Roshan,
    it because at sourcing time there is no GUI
    please add this line at beginning of hwinit.tcl :
  • Roshan Shiveshwar
    edited April 2018
    Thanks tinh !!
    That was helpful.
  • Ajay Prabhakaran
    Ajay Prabhakaran Altair Community Member
    edited August 2023
    Hello Tinh
    Do you have any idea how to run a tcl script before starting Hyperworks. hmcustom.tcl will run after Hyperworks GUI is loaded.
    I am using Hyperorks 2022.3.
    My idea is to update the extension file before the HW GUI is loaded
Welcome!
Welcome!
