offset of shell elements
Hello,
i have shell-elements and i assign them an offset.
Mesh/card edit/elements
It works very well.
Now i can´t edit the offset. I don´t now whats wrong because i did it the same way at last. The config is quad4 and the type is cquad4 there are equal to the element.
If i try to edit only one element there pop up the error message:
One entity selected, ignoring coniguration and type specification.
???? The element i try to edit ist exactly a quad4. If i use the 'select tool' (yellow butten: elems) in the card edit panel by using the option by config with config= quad4 and type=cquad4,
the element was selected.
Magic or adjustment in hm?? /emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
