🎉Community Raffle - Win $25
Join and Win
offset of shell elements
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
i have shell-elements and i assign them an offset.
Mesh/card edit/elements
It works very well.
Now i can´t edit the offset. I don´t now whats wrong because i did it the same way at last. The config is quad4 and the type is cquad4 there are equal to the element.
If i try to edit only one element there pop up the error message:
One entity selected, ignoring coniguration and type specification.
???? The element i try to edit ist exactly a quad4. If i use the 'select tool' (yellow butten: elems) in the card edit panel by using the option by config with config= quad4 and type=cquad4,
the element was selected.
Magic or adjustment in hm?? image/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
1 - 4 of 41
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    BeMa86,
    Please see   Altair Support Forum  → Modeling and Assembly (Preprocessing)  → HyperMesh --> How to delete settings files
    http://forum.altairhyperworks.com/index.php?/topic/13434-how-to-delete-settings-files/
    and delete the settings files and let me know if the problem persists, please also attach images and your system info, version, HW updates etc at that time,
    Altair Employee
    OP
    Hallo Rahul,
    thank you for your answere. I closed Hm and delet the the settings files. Then i opened the model and try it again. It dosn´t work.
     Altair Home: C:/Program Files/Altair/12.0
     Updates Information:
    hwdesktop12.0.110
    hwdesktophelp12.0.110
    hwsolvers12.0.220
    hwsolvershelp12.0.220
    sT9.5_hw12.0
     Versions:
    hgtrans.exe:                  12.0.110.40 (Sep 13 2013)
    hmopengl.exe:                 12.0.110.40 (Sep 13 2013)
    hst_ng.exe:                   12.0.110.40.500186 (Sep 13 2013)
    hstbatch_ng.exe:              12.0.110.40.500186 (Sep 13 2013)
    hstdss.exe:                   12.0.110.40.500186 (Sep 13 2013)
    hvp.exe:                      12.0.110.40 (Sep 13 2013)
    hw.exe:                       12.0.110.40 (Sep 13 2013)
    hwmbdmodel.dll:               12.0.110.40 (Sep 13 2013)
    hwplot.dll:                   12.0.110.40 (Sep 13 2013)
    hwplot3d.dll:                 12.0.110.40 (Sep 13 2013)
    hwpost.dll:                   12.0.110.40 (Sep 13 2013)
    hwtext.dll:                   12.0.110.40 (Sep 13 2013)
    hwvideo.dll:                  12.0.110.40 (Sep 13 2013)
    hwx.exe:                      12.0.110.40 (Sep 13 2013)
    templex.exe:                  12.0.110.40 (Sep 13 2013)
     System Information:
    Machine:                      amd64
    OS:                           windows Windows NT 6.1
    User:                         Maresch
     Hardware:
    Processor:                     Intel® Xeon® CPU E5-1620 0 @ 3.60GHz (8 CPUs), ~3.6GHz
    System Manufacturer:           FUJITSU
    System Model:                  CELSIUS M720 POWER
    Total Physical Memory:         16384MB RAM
     Operating System:
    Machine name:                  RP-TB546
    Operating System:              Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130708-1532)
     Graphics/Display/OpenGL:
    Card name:                     NVIDIA Quadro 2000
    Chip type:                     Quadro 2000
    Display Memory:                681 MB
    Driver Name:                   nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver Version:                9.18.13.2723
    Current Mode:                  1920 x 1200 (32 bit) (59Hz)
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    BeMa86
    I am afraid I do not see the problem in a machine with the same specs and same version with updates of HW.
    Can you delete all these files and try?
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-48130100-1409826866_thumb.jp
    Altair Employee
    OP
    I delet all these fils.
    Start HM and load the .hm file.
    It dosn´t work.
    I export a solver deck to Nastran and a Frind can change the offsets. So the Model is ok.
    Is there a adjustment, how prevent the card edit option?
