Bending simulation
Hi
i am doing 3 point roll bending simulation in that i need to gradually increase the top roller displacement (i.e) at first stage top roller displacement is given as 2 units then the plate is rolled.
After this i need to apply the top roller displacement at the same point on the plate and again rolling need to be done. since it is having friction and slip i cant able to find position at the exact point. is there any way to do by creating a separate engine file or any other way like .sta file
thanks
Shrinaath
