🎉Community Raffle - Win $25
Join and Win
PWM generator Outputs
User: "Lotfi Beghou"
Altair Community Member
Updated by Lotfi Beghou
Hello,
For my application, I would like to use the same PWM generator in two different output modes. In a 1st time I would like to start with using A only after which, I would like to switch to use A&B.
Thank you in advance for your help
1 - 2 of 21
    User: "Rhonda_20369"
    New Altair Community Member
    Updated by Rhonda_20369
    Hi, Lotfi,
    When you are "using A only", do you mean that you want B output to be in a "logic low" state?
    If so, you may use a "2-phase PWM" block.
    The 2-phase PWM block receives 2 inputs, one for A and the other for B.
    You may use a logic gate to control the input to B so its output is logic low as long as you want.
    OP
    Thank you Rhonda for the solution, much appreciated.
