Composite Plies
When trying to run an Analysis with COMPOSITES I get the following error:
*** ERROR # 1901 *** in the input data:
STACK must have either a list of PLYs or substacking data.
Where do I define the list of Plies for the STACK? I have defined PLIES for the properties.
Any help would be appreciated.
Rgds Bernt
Hi Ben
I use 2021 version. I have access to 2021.2 but have not used it for this project. Yes, I am using the PCOMPP property card.
Should I switch to using the 2021.2 version?
Thanks for your patience I probably confused things a little.
The easiest way (IMO) to deal with composites is in the composites browser. I prefer to use HyperWorks where this is located on the model ribbon. You can also get to it in HyperMesh under View>Browsers>HyperMesh>Composites.
Once there any plies that are not assigned to a laminate will be in an "Unstacked Plies" folder in the tree. You can then drag and drop plies into the different laminates, reorder them by dragging and dropping and do many other modifications.
Bernt,
This is where you add it. Let me know if that fixes your problem.
Thanks,
Ben
