Have pipe separated values in .txt file. How to define Model?
I have a text file that has columns separated by the "|" (pipe) character. Some fields are variable in length, so the columns following are not in the same place as the row above or below. This is probably a beginner question. I want to define a model that recognizes the text file similar to a .csv file. Am using Monarch Pro V11.2
