TCl scripting
I am performing NVH simulation in which, the forces from flux are obtained as a bulk file which are then needed to be imported into optistruct.
Since, there are some issues that are being faced in the flux-optistruct interfacing, I would like to import the forces from bulk file into Optistruct using TCL scripting commands,
Is that possible. If so, what are the main commands that would be used in such a case?
I had imported the bulk file and processed the solve. But, it yielded rload2 data missing error.
When tried to recreate the force file by importing the tooth profile from Optistruct to Flux, it yielded exception error which were unable to be resolved.
And hence, I am trying to use the available force file to get imported into Optistruct using scripting method.
First please tell why you don't import bulk format forces using GUI?
