Selecting co-linear nodes
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello , Good Morning everyone
I am trying to prepare a script which will
1.go through geometry detect all holes
2. detect for co linear holes 2 or more, note center nodes
3. create a spider with hole and center node and beam between two hole center
Right now I am able to achieve 1st and 3rd step but not able resolve second step
Any one have any suggestion for this?
Thank you
1 - 5 of 51
    User: "tinh"
    Altair Community Member
    Updated by tinh
    I think hm_detecthole module can do it. It returns center and axis vector of holes which you can compare to find matches
    Did you try these commands?
    Looking for them in reference guide (v14 or higher)
    Altair Employee
    OP
    Hello tinh,
    Didnt found hm_detecthole command. But I know about hm_ce_gethmholes it gives center hole location but wont provide any info on axis
    Thank you
    Altair Employee
    OP
    hi tinh,
    did't found this command in v14. if u have..can u pls share the syntax for the same
    User: "tinh"
    Updated by tinh
    sorry, correct command is
    hm_holedetectioninit
    please read usage and example in hm reference help for this command
    Altair Employee
    OP
    YUP GOT IT....THANKS TINH
