🎉Community Raffle - Win $25
Join and Win
How to manage the model of a truss
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm working on a optimization of a steel element: I have a truss (traction and compression) rod that connects to the element to be optimized.
My question is how should I consider the axial force on my rod (is a hollow circular section rod)?
The hub in which the rod is raised is non-deformable, how can I set this element? How can I connect this hub to the element to be optimized so that the forces are transmitted?
How can I match the mesh of the two different components?
Thank you very much
<?xml version="1.0" encoding="UTF-8"?>IMG_6528.thumb.jpg.26644aabbf1309d4a5d806ce6725007a.jpg<?xml version="1.0" encoding="UTF-8"?>921388915_Schermata2018-11-29alle16_52_53.thumb.png.f1e66013d4a23771f6d1e28138667857.png
1 - 5 of 51
    User: "tinh"
    Altair Community Member
    Updated by tinh
    You can connect it by RBE2
    (Panel 1d>rigid)
    Altair Employee
    OP
    Hi albertolazzeri
    You can create rigids and apply force as shown to an hollow cylinder.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.e80da7d9bed1641f3c50c973b9f8e73c.png
    Also, i see there is no connectivity between the hollow cylinder and surrounding elements. To have the connectivity, delete the surrounding elements (only one layer of elements, which is marked in red), then create elements manually using Ruled option in 1D page.
    Thank you
    Altair Employee
    OP
    Thank you very much for your suggestions, is correct to create a RBE2 in a middle node inside the hollow and connect it to the internal surface of the cylinder?
    Which is the difference between your method and my test? I want to study the condition in which the cylinder is non-deformable. If instead I wanted to include the cylinder in the optimization of the element connected to it, what I have to change in the setting?
    Thank a lot
    Altair Employee
    OP
    The elements which you want to optimize Define it as a design space and the cylinder which you don't want to be affected define it as a non design space.
    Please refer our eBook  'Practical Aspects of Structural Optimization (A Study Guide)'. Where, we have explained each and every optimization technique in detail.
    You can download the book from below link.
    https://altairuniversity.com/free-ebooks-2/free-ebook-practical-aspects-of-structural-optimization-a-study-guide/
    Below example in OptiStruct help section is similar to your problem. Please refer.
    OS-T: 2010 Design Concept for an Automotive Control Arm
    Thank you
    Altair Employee
    OP
    Thanks for the advices, I'm already trying to follow the ebook but sometimes external suggestions are useful to avoid wrong choices.
    The example you told me  is what I need.
