How to manage the model of a truss
Hello,
I'm working on a optimization of a steel element: I have a truss (traction and compression) rod that connects to the element to be optimized.
My question is how should I consider the axial force on my rod (is a hollow circular section rod)?
The hub in which the rod is raised is non-deformable, how can I set this element? How can I connect this hub to the element to be optimized so that the forces are transmitted?
How can I match the mesh of the two different components?
Thank you very much
<?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>
