Altair RISE
Nominate Yourself Now!
Elements in proximity of nodes
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
When a list of nodes is imported to a meshed model, is there a way to find what elements are near each imported node, given a certain tolerance?
If so, how to select and export these elements?
Thanks for your help.
Regards,
N.
1 - 5 of 51
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi @NFMOREIRA
    If the nodes are associated with the elements, there is option to find attached using TOOLS > FIND option in HyperMesh
    However there is no direct option to find based on Tolerance. For this you may need to do customized scripting or automation.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.c539307ab988682a62b70d981265a0d0.png
    Altair Employee
    OP
    Hi Pranav
    Exactly. I use that  command for attached elements.
    For this case however, I would need to do a script. The problem is that I do not know at the moment, how to transform the idea into the script.
    User: "Pranav Hari"
    Hi NFMOREIRA
    You can learn the basics of scripting from the online tutorials available in HM help.
    Hope these links may help you.
    Altair Employee
    OP
    Thanks Pranav :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "vipin_22401"
    Updated by vipin_22401
    Hello,
    Regards,
    N.
    Hi @NFMOREIRA
    ::hwat::utils::GetClosestElement x y z assemname
    May be this is the command you are looking for, x y z are the coordinates of corresponding node.
