Missing graphics while exporting Inspire as mdl-file
RoKetUser: "RoKet"
Altair Employee
Updated by RoKet
I'm playing around with the new demo models for Inspire and MotionSolve (https://altairhyperworks.com/motionsolve-models/) and export the model 'Landing Gear - 4 Wheels' to MotionSolve. When I open the model (.mdl) in MotionView, the connections between graphics and the components in x_t-file are broken (no box checked in the Components list). Also the names of the componets are not the same as in x_t-file, otherwise I could restore the connections by name.
How can I avoid this problem?
Thanks for help,
Ronald
1 - 2 of 21
    asajd_20372User: "asajd_20372"
    New Altair Community Member
    Updated by asajd_20372
    Inspecting the MDL file you provided there appears to be a mismatch between the part name and the internally represented name embedded in the CAD.  Think of it as being a 'mapping problem'.  This isn't your fault.  The attached 'LG_parts.txt' file shows what I believe the part mapping ought to be.
    Try using the attached MDL and Parasolids file and see if that works out better for you.
    Sincerely,
    asajd
    RoKetUser: "RoKet"
    Altair Employee
    OP
    Updated by RoKet
    Hi asajd,
    Thanks for solving the mapping problem. With your files it now works fine. I just had to rename the file 'Landing_Gear_4_wheels_x_t.8bbc17520c5a14e4688199a9da4b1a66' into Landing_Gear_4_wheels.x_t'.
    Ronald
