🎉Community Raffle - Win $25
Join and Win
Volume tetra
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
Two Question:
1. If you use proximity meshing is Hypermesh using a 10-knotes tetrahedral elements?
2. If you use 'curvature' is the function 'proximity' automatically set?
Best regards
1 - 3 of 31
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    See HyperWorks Desktop Applications > HyperMesh > User's Guide > HyperMesh Panels > HyperMesh Panels Listed Alphabetically:
    Tetramesh Panel
    Proximity refines the mesh in areas where the features are small and closer together
    If you need to use 10 node tetras, go to preferences > meshing options > choose second in element order
    You will have to choose curvature and proximity separately,
    Altair Employee
    OP
    Hi, I'm using volume mesh and when i try to export the file in stl format i get the message 'save invalid elements to user mark?' if i click yes and try to open the file in forge nxt it doesn't open.
    please tell me the cause of the message.
    Thank you.
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Stl is triangle mesh. If you have other element types in model exporter will issue the message
    Try f5>elems>retrieve >mask>reverse to see them
