Two Question:
1. If you use proximity meshing is Hypermesh using a 10-knotes tetrahedral elements?
2. If you use 'curvature' is the function 'proximity' automatically set?
Best regards
See HyperWorks Desktop Applications > HyperMesh > User's Guide > HyperMesh Panels > HyperMesh Panels Listed Alphabetically:
Tetramesh Panel
Proximity refines the mesh in areas where the features are small and closer together
If you need to use 10 node tetras, go to preferences > meshing options > choose second in element order
You will have to choose curvature and proximity separately,
Hi, I'm using volume mesh and when i try to export the file in stl format i get the message 'save invalid elements to user mark?' if i click yes and try to open the file in forge nxt it doesn't open.
please tell me the cause of the message.
Thank you.
Stl is triangle mesh. If you have other element types in model exporter will issue the message
Try f5>elems>retrieve >mask>reverse to see them
