Stress Contours on 2D or 3D mesh
Mesh1
Mesh1 Altair Community Member
edited April 2022 in Community Q&A
I have a 3D part that was 2D surfaced meshed and then 3D elements created.
It seems as if the stress contour results were set-up on the 2D mesh only.
Meaning the interior of the part does not have results, only the "skin"
Why would it be set up this way ?
Hypermesh using Abaqus
Welcome!
Answers
  • Jason_Craanen
    Jason_Craanen
    Altair Employee
    edited April 2022
    Make sure you are requesting the correct results output. And make sure you are contouring the correct results output. It would be helpful if you share a picture.
  • Mesh1
    edited April 2022
    Hi Jason, I sorted it out. Well, partially.
    I now realize that the models I have been working with have both 3D elements , and 2D membrane elements.  The results are out putted for the 2D elements.
    Do you know how to to set-up the output to specify which mesh you want the solution for ?
  • PaulAltair
    PaulAltair
    Altair Employee
    edited April 2022
    I'm not an abaqus user, but check your output requests in elfile for S, SINV etc, and that the 'element set' request isn't set for just a reduced set of your elements (if element set is omitted it should be outputting results for everything)
Welcome!
Welcome!
