Error 286
I am running a nonlinear dynamic crash analysis on my chassis and getting the following error
ERROR ID: 286
** ERROR IN INPUT CONSISTENCY
DESCRIPTION :
2D SOLIDS (QUADS AND TRIAS) ARE NOT COMPATIBLE WITH 3D. CHECK N2D3D VALUE
I have checked for the element types. I have attached my hm file also.
Please help me out. Thank you in advance.
1 - 3 of
31
can you check if your model doesn't mix solids and shells inside the same component/part?
Probably this is the case.
