INTERNAL PROGRAMMING ERROR
Hi,
i am performing buckling analysis but getting error as show in below.
*** INTERNAL PROGRAMMING ERROR ***
in file 'xdsemx_i8.F', at location # 262.
ioerr(1) = 1
**** ABORTING RUN DUE TO AN INTERNAL ERROR ****
i am using Optisrtuct 2018 version
how to solve this error?
Thanks and Regards,
Narasimhamurthy
Defined PARAM, LGDISP, 1
but getting same error.
Please find attached output file.
Could you also add PARAM, KGRGD, YES as per the warning mentioned in the .out file. If it gives an error, then please share .out and .stat file.
Please remove special character (- _ . % etc)used in part name/file name/user name & also change the run folder.Run again and let us know the outcome.
not yet solved.
Please find attached output file and stat file.
Can you give a final try by unchecking output request or param cards defined.In the past we have seen this programming error is mainly observed because of output request /param.
removed all PARAM and output request.
but error not yet solved.
Last shared files are based on 2017.2.So I am commenting based on the files shared in this quote using 2018.0.1
This is related to some IO issue during a matrix vector multiplication in Lanczos. I am afraid I will need the model to see what could be the problem but as a workaround you could try using MUMPS as the lanczos solver via the solvtype card and see if it works out. Alternatively you could try ddm mode (even with 1 proc).
Could you just add PARAM,LGDISP,1 and run again.It seems this was fixed in the version(2018.0.1) which you are currently using.
