Where can i get files from examples in help?
Updated by Altair Forum User
Hello,
i am trying to find example files, which should be located in installation folder under */tutorials/demos/
Specifically, i was trying to find Radioss file 19 - Wave propagation to check how to use Boundary elements.
I cant find neither these files neither the folder anywhere, although i installed the desktop help and solver help.
Please help where can i get these example files.
Thank you,
Ales
1 - 5 of
51
Hi,
thanks for your reply.
I use student edition. The demo files are not in the student version?
Ok, thank you.
One more question - Bulk data format for Radioss is also not available in student edition, right?
New Altair Community Member
Updated by Rahul Rajan_21763
Hi,
Radioss bulk is called as Optistruct from Hyperworks 12.0 onwards.
Regards
Rahul R
Hi Ales,
are you using the full version of the software and not the student edition?
They should be in the installation folder if help was installed, C:\Program Files\Altair\13.0\demos for example,
you may have to uninstall / reinstall and make sure the installation path is entered correctly when help is being installed,
