🎉Community Raffle - Win $25
Join and Win
Output of stress results
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
is there any possibility to directly output stress results from Hypermesh? I know that I can query results in Hyperview but is there any
way to directly generate an output file with the stresses?
I tried with .pch but it seems that with .pch I can only output the stresses at Z1 and Z2 but not MID?
1 - 7 of 71
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    which solver you are using?
    Regards
    Rahul R
    Altair Employee
    OP
    I am using OptiStruct!
    Regards
    Margit
    Altair Employee
    OP
    Talking about the output of stress results: When I use the query tool in hyperview and export the node id, node corrdinates and Tensor(Grid Point Stresses (Global)) I receive 6 Values for the Tensor. In what order are these values? Or asked the other way around: Is XX, XY, YY, YZ, ZX,ZZ correct or is it another order?
    Thanks a lot!
    Altair Employee
    OP
    Asaad,
    the stress tensor components are ordered as follows: xx, yy, zz, xy, yz, zx
    Altair Employee
    OP
    Thank you Margit!!!
    I will need to have a source for that for my documentation. Do you know where to find something proper? I couldn't find this information in the altair help files..
    Altair Employee
    OP
    To be honest I wasn't able to find the order of the stress tensor components in the altair help as well.
    I got to this conclusion by comparing the values in the .pch (PUNCH file) with the hyperview query export as for NASTRAN (.pch) the order of this values is well documented ....
    Altair Employee
    OP
    Aaaah! Smart ;D
    Thank you!
    When you to that tensor plot for Grid Point Stresses (Global) it shows the Order (XX YY ZZ XY YZ ZX) in the plot window in the upper left above the colour scale^^
    To obvious to be found there :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
