1 - 7 of
71
Hello
I'm having a similar issue with excessive model loading times.
I'm trying to open a .hm file, 102MB in size. The loading status stops at 'reading tags'.
The problem appeared a while ago, and keeps getting worse. A couple of days ago the
loading time was around 10 minutes, but now nearly two hours have passed and the model still hasn't loaded.
A colleague also encountered this problem. I'm working on HW version 9.1 The problem persists on other work stations.
Peculiarly, HW 12 is able to load the file without any issues. Sadly, migration to HW 12 is not a viable solution.
I'm working on Windows XP 64bit, Service Pack 2; running on a Intel 2 Duo E6750@2.66 GHz with 4 GB of RAM and a Geforce 8600 GT.
Hi Kejohnson,
just wanted to confirm few things
Is it a .hm file or a solver input file
which operating system you are working on.
also please send the system details.
Regards
Linus
