Altair RISE
Nominate Yourself Now!
Boolean operation
User: "jss"
Altair Community Member
Updated by jss
how to subtract two tetramesh components from one another in hypermesh?
 I was having stl files, then I have converted them into 3D tetramesh. Now i want to subtract volume of one part from other.
1 - 7 of 71
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Latest version of HyperMesh 2019.0 provides Tetramesh updates for geometry modification. Please refer attached video.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    @Rahul R Tetramesh update based on geometry modification is USELESS for the question of @jss. His 3D mesh is based on STL, not geometry.
    User: "jss"
    OP
    Updated by jss
    yes, my 3D mesh is based on stl. I don't have solid geometry.
    User: "jss"
    OP
    Updated by jss
    I cannot select solids in boolean opeartion. STL parts are converted into 3D mesh
    User: "tinh"
    Updated by tinh
    Convert stl back to solid geometry,
    Subtract geometry parts
    Then convert geometry to stl to finish!
    User: "jss"
    OP
    Updated by jss
    Thank you for your suggestion. But It is not clear to me, how to convert stl to solid geometry? STL file has very irregular and complicated shapes.
    Menu : 'Geometry' => Create => Surface => From EF
    When you have closed surfaces, you can create Solid.
