HyperStudy FluxMotor Error "FmHidenException: System error#12"
User: "Riccardo Traversari"
Altair Community Member
Updated by Riccardo Traversari
Hi,
I don't understand the reason of the following error: "FmHidenException: System error#12". It appears when I try to run a FluxMotor 2021 model from HyperStudy 2021.2. Please take a look to attached documents.
The FluxMotor model works correctly if I run the simulation outside HyperStudy.
When I run the same HyperStudy study in a different workstation, It works correctly.
Best regards,
Riccardo
1 - 4 of 41
    User: "Diana_38240"
    Altair Employee
    Updated by Diana_38240
    Hello Riccardo,
    Thanks for contacting us. I'm Diana and will help you with your request.
    Would it be possible to share the study archive (*.hstx file) so that I can run it on my side and try to reproduce it?
    If you prefer you can post a ticket through the support? I'll take it from there.
    Best regards,
    Diana
    OP
    Hi Diana,
    I'm going to post a ticket. Could you provide to me the support service link?
    Thanks!
    Best regards,
    Riccardo
    User: "Diana_38240"
    Altair Employee
    Hi Diana,
    Thanks!
    Best regards,
    Riccardo
    Hi Riccardo,
    You can submit it directly from the Community page. Please join the archive (*.hstx), from menu File-->Export or Save
    Contact support
    Best regards,
    Diana
    User: "Diana_38240"
    Altair Employee
    Hi Riccardo,
    Contact support
    Best regards,
    Diana
    Hi Riccardo,
    Just wanted to check if this was solved? Did you contact the support?
    Regards,
    Diana
