Modeling & Analysis of Particulate Composites
Hi
I want to do analysis of particulate composite in Hyperworks.
I have to create a geometric model of the composite than i will have to do the nonlinear analyis. But i am not getting that how we can do this type of analysis.
A lot of material is there for laminated composiute analysis, but not about particulate composites.
Can anyone suggest me that how a 3D model of a particulate composite materila can be created and how we can do the analysis for the same.
Dear Atakan
Thanks for your reply. But i want to know about:
Making a geometric model of particulate composite having different shaped particles of one material reinforced into other material. ( A cuboid of one material having different shaped particle of the other material)
Secondly how diffenet properties can be assigned to these two materials
Third how the contact between the two materials can be treated differently ( Like perfect bonding or debonding etc)
I will be thankful if some could help me out.
Raghav
Raghav,
I understood from your answer that you want to model the behaviour of the particulate composite. I mean, you don't know the properties of the composite, but you know the properties of the particles and matrix.
Am I right?
HI, Raghav did you find the answer to your problem , I'm kind of stuck in the same place. I wish to model a polymer say (PE) as matrix and aluminium oxide particles.
can someone tell how can we create particle reinforces composite in hyperworks ??
Hi;
Particulate composites can be modeled as linear and isotropic material. Thus, you can use MAT1 card.
Atakan
