Hi, When simulating with low pressure casting, when I run it with the run command it gives a Meshing error. What should I do?
Hello,
Can you attach your model setup here? I can check what is going on.
Regards.
Hello, Can you attach your model setup here? I can check what is going on. Regards.
Please let me know if there was any wrong drawing or if I sent documents missing.I tried it first with holes. Then I closed the holes and tried again. I encountered the same error in both. Thanks again
I attached the file that you want and hope it is a correct file.
Thanks in advance,
Regards,
