radiation setting, how?
Hi,
In the solar radiation model mentioned that:
specular transmissivity + diffuse transmissivity + specular reflectivity + diffuse reflectivity + absorptivity = 1
The questions are:
1) In Acuconsole, absorptivity does not need to specify. So, is it means that it is automatically generated based on above equation?
E.g: 0.5+0+0.2+0+absorptivity=1
Is it means that absorptivity value automatically = 0.3??
2) Is it emissivity value must be equal to absorptivity value??
Thanks
Sorry for my english..
1. Yes absorptivity is the rest of the equation, as you mentioned
2. AcuSolve takes absoprtivity = emissivity and hence you once specify emissivity
Regarding question 2, if we setup specular transmissivity = 0.35, specular reflectivity = 0.05 and emissivity = 0.6
what is value of absorptivity?
Thanks
