RBE3 elements and boundary conditions
Good afternoon,
I am simulating a chassis structure, and I want to simulate the posibility that extreme supports can rotate (there is no restriction from wheels, as I send attached the picture. I am thinking into define a node, connect it with the two supports from my chassis, and restrict the dof of the node (X and Y displacements and X and Y rotations in one side, and Y displacements and X and Y rotations on the other side). How can I do that in Simlab? Thanks in advance.
Note: X and Y are included on the plane of the drawing.
Hello JJJ
You can connect the supports in the chassis to the defined node using RBE from Analysis > Loads & Constraints > Connectors > Manual RBE
<?xml version="1.0" encoding="UTF-8"?> <?xml version="1.0" encoding="UTF-8"?>
For restricting the DOF's of the Independent node of the created RBE's, apply Property from Analysis > Property.
Select the RBE's from the Model browser. Set the Entity as RigidBar & Type as Rbe2. Set the DOF of the Independent node in the DOF tab.
Kindly let us know if you have any doubts.
Note: I have already replied to your query in the following link
https://community.altair.com/community?id=community_question&sys_id=f266403a1b2bd0908017dc61ec4bcba7
Thanks & Regards
Nantha Kumar N
Hello, anyone could help me? Thanks.
