Method to create a set of lines,surfaces or points
Benevant
Benevant Altair Community Member
edited October 2020 in Community Q&A
Hello all,
is there a way to create sets contain lines, surfaces or points.
My aim is the call those sets or lists in a tcl script.
thanks in advance
Welcome!
Answers
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited August 2020
    I don't think there are such type of set. If you work from Tcl script, you can keep your lines, surfaces, points ID in LIST variable.
    Here's an example:
     set myLines [list 1 2 3] set myPoints [list 10 11 12] set mySurfaces [list 30 31 32]  # Mesure shortest distance from surface 30 to set of lines *createmark surfs 1 [lindex $mySurfaces 0] *createmark lines 1 $myLines hm_measureshortestdistance surfs 1 0 lines 1 0 5
  • Benevant
    edited August 2020
    Hello /profile/43398-qnguyen-dai/?do=hovercard&referrer=https%253A%252F%252Fforum.altair.com%252Ftopic%252F40605-method-to-create-a-set-of-linessurfaces-or-points%252F%253Ftab%253Dcomments' href='<___base_url___>/profile/43398-qnguyen-dai/' style='background-color:transparent;color:inherit;' title='Go to Q.Nguyen-Dai's profile' rel=''>Q.Nguyen-Da
    The below script is crashing hypermesh.
    set elem_size 0.25
    set count 2
    #create sets of lines-- each sets is for each solid map
    for {set a 1} {$a<$count+1} {incr a} {
        *createmarkpanel lines 1 'Select lines'
        set lines$a [hm_getmark lines 1]
        *clearmark lines 1
    for { set a 1}  {$a < $count+1} {incr a} {
        *createmark elems 1 'by sets' 'set$a'
        set source_elems [hm_getmark elems 1]
        set along_line lines$a
        *solidmap_begin 0
        *solidmap_prepare_usrdataptr 'SOURCE' 24
        *createmark elements 1 $source_elems
        *solid_prepare_entitylst elements 0
        *solidmap_prepare_usrdataptr 'DEST' 0
        *solidmap_prepare_usrdataptr 'ALONG' 2
        *createmark lines 1 $along_line
        *solid_prepare_entitylst lines 0
        *solidmap_end 8322 $elem_size 0 0
    I was trying to loop the line drag for 3D modelling. The panel is displayed below.
    image.png.794b208bbf326266337619236aed9a28.png/uploads/monthly_2020_08/image.png.794b208bbf326266337619236aed9a28.png' />
    The varying inputs are elems to drag and along geom.
    Would you check the above script and give some suggestions.
    Thanks
  • QuyNguyenDai
    edited August 2020
    I can not see the error message?
Welcome!
Welcome!
