Pressure on arc segment of a surface
Lukas Rehermann
Lukas Rehermann Altair Community Member
edited July 2021 in Community Q&A
Hello,
I'm struggling to apply a pressure on an surface on a wheel. I want to apply the pressure on an arc segment of the wheel (marked in yellow) and not on the whole circumference:
In Hypermesh I only can select the whole surface.
My idea is to create planes with an angle of +-20° to the XY-plane and create curves on the rim using these planes. The pressure should be applied to the surface which is limited by the curves. The problem is that I don't know how I can create the mesh considering the curves on the surface and how to select this surface when applying the pressure.
I used the IGES-format for transfering the part from NX to Hypermesh, if this is relevant.
Does anybody have a recommendation for this? Or do you have a different approach to solve my problem?
I'm not really experienced with Hypermesh, so I would be really glad if anybody can help me.
Best regards,
Lukas
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2021
    If you still have the geometry associated with your mesh, then you could select 'elems >> by geoms'
    Make sure you have changed selection from 'faces' to 'elems'.
    I think this could help you.
  • Lukas Rehermann
    edited July 2021
    Thanks for your reply! Unfortunately, this does not solve the problem. When I try this, the elements are not selected. Does anybody else have an idea for solving this? Or do you have a different idea?
  • Lukas Rehermann
    edited July 2021
    I found a solution for the problem, even tough it is not very nice.
    I created lines on the surface of my wheel in NX. These lines are the borders of the surface I want to apply the pressure on. In Hypermesh I used the tool "Split by lines" to split the surfaces. After that the mesh is created according to the borders and I can select the elements manually.
    As I said, it is probably not the best solution, but it works.
Welcome!
Welcome!
