I'm struggling to apply a pressure on an surface on a wheel. I want to apply the pressure on an arc segment of the wheel (marked in yellow) and not on the whole circumference:
In Hypermesh I only can select the whole surface.
My idea is to create planes with an angle of +-20° to the XY-plane and create curves on the rim using these planes. The pressure should be applied to the surface which is limited by the curves. The problem is that I don't know how I can create the mesh considering the curves on the surface and how to select this surface when applying the pressure.
I used the IGES-format for transfering the part from NX to Hypermesh, if this is relevant.
Does anybody have a recommendation for this? Or do you have a different approach to solve my problem?
I'm not really experienced with Hypermesh, so I would be really glad if anybody can help me.
Best regards,
Lukas
