How to create Sets simultaneously on two sides of a Surface?
1 - 4 of
41
Hello Adela,
In Radioss the orientation of the surface is not important for the contact. When you create it, it already considers both sides.
Does this answer your question?
Kind regards,
Guilherme
So if I create "Sets" on both sides of a Surface, will the problem result be more correct or will it still be the same when there are only "Sets" on one side?
Hello Adela,
Kind regards,
Guilherme
