🎉Community Raffle - Win $25
Join and Win
2mm washer line generation script
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello all,
I am trying to develop a scripct in order to create 2mm washer. However script has a mistake that I coud not find. Can you help me about this topic?
*createmarkpanel lines 1  'select lines to create washer'
set lst '[hm_getmark lines 1]'
foreach lsts $lst {
*trim_by_offset_edges 0 $lsts 2 0 0 0
1 - 4 of 41
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Try:
     *createmarkpanel lines 1  'select lines to create washer' set lines [hm_getmark lines 1] foreach line $lines { 	eval *createmark lines 1 $line 	*trim_by_offset_edges 0 1 2 0 0 0 	*clearmark lines 1 }
    Altair Employee
    OP
    Thank you for your help.
    Altair Employee
    OP
    DO WE HAVE SCRIPT FOR DOUBLE LAYER WASHER ONE SHOULD BE OF 1.5*D AND THE OTHER LAYER MUST BE 5MM+FIRST LAYER
    User: "tinh"
    Updated by tinh
    Oh, just first generate 5+1.5D washer then generate 1.5D one
