I am selecting 3 nodes somewhere in my model in order to define a plane using the
*createmarkpanel nodes 1 'Select 3 nodes!'
command. In the process of the selection I am using the plane/line/edge highlight feature provided by HyperMesh(I keep pressing the LMB until it turns to a rectangle and then select a geometric feature). The problem is that the highlighted surfaces stay highlighted even after I've pressed the 'proceed' button.
Is there any way to undo the selection?
Regards, Stefan
