Element Merging Feature
Hi,
I wonder if there is any element merging function in HM that can automatically element sizes and then merge neighbouring small elements? For instance, merge all elements smaller than size of 0.3 with their adjacent elements by collapsing edges, merging nodes etc.
Many thanks,
Wensong
/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
It could have a 'semi' automatic method:
1)F10>check elems size <0.3 >Save failed
2)F12>elems >retrieve>elems>by adjacent> mesh
Hi Tinh & Prakash,
Thanks for replying! I had a go at what you had suggested but found F12 i.e. 'Automesh Panel' only works for 2D meshes?
Is there a similar feature for 3D Tetrahedrons, too?
Prakash, if I have to merge the elements manually or with TCL scripts, what are the key steps and functions that I will need to use? I have tried 3D->edit element->cleanup but that will be totally manual, right?
Many thanks for your help.
Regards,
Wensong
Hi Prakash,
Hmm, element combine function is also not applicable to 3D tetra element I think. Any other suggestions?
Cheers,
Wensong
Hi
1)F10>3D>check tetra elems size <0.3 >save failed
2)d>display none elems
3)F5>find attach>elems>retrieve>find
4)Tools>faces>elems>select displayed elems>elems>save>find faces
5)F2>elems>retrieve>delete
6)3D>tetramesh>tetra mesh >select face elems>mesh
(set tetra elems size at 3D>tetramesh>tetramesh parameter)
/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
Hi Wensong,
there is no such option available in HyperMesh which can automatically combines elements which falls below a specific size.
You may consider writing a TCL script to automate this process
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
