Thermal Stress Analysis on a Heatsink
SAI VIJAY CHANDRA GAJULA
SAI VIJAY CHANDRA GAJULA Altair Community Member
edited June 2021 in Community Q&A
Material :- Isotropic : Aluminium Alloy Element Type :- Tetra elements  Temperature on bottom face :- 230 degrees  Constraints : Side faces
how to create a good mesh for these component and help me in step by step processesimage
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    i reccomend you to go through a basic HM training in order to learn all the features that could make your life easier.
    In general you could:
    - create a shell mesh for the desired faces (seed), controlling the mesh quality and then create the volume mesh. (2D >> automesh)
    - trim the solids or the surfaces, to have a better control over the mesh (geom>>solid edit). By having smaller solids, usually it is easier to get more control for meshing (although too small solids will generate bad elements).
  • SAI VIJAY CHANDRA GAJULA
    edited June 2021
    can you please suggest hm training link
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    Going through Altair University
    https://certification.altairuniversity.com/course/index.php?categoryid=63
Welcome!
Welcome!
