Material :- Isotropic : Aluminium Alloy Element Type :- Tetra elements Temperature on bottom face :- 230 degrees Constraints : Side faces
how to create a good mesh for these component and help me in step by step processes
i reccomend you to go through a basic HM training in order to learn all the features that could make your life easier.
In general you could:
- create a shell mesh for the desired faces (seed), controlling the mesh quality and then create the volume mesh. (2D >> automesh)
- trim the solids or the surfaces, to have a better control over the mesh (geom>>solid edit). By having smaller solids, usually it is easier to get more control for meshing (although too small solids will generate bad elements).
i reccomend you to go through a basic HM training in order to learn all the features that could make your life easier. In general you could: - create a shell mesh for the desired faces (seed), controlling the mesh quality and then create the volume mesh. (2D >> automesh) - trim the solids or the surfaces, to have a better control over the mesh (geom>>solid edit). By having smaller solids, usually it is easier to get more control for meshing (although too small solids will generate bad elements).
can you please suggest hm training link
Going through Altair University
https://certification.altairuniversity.com/course/index.php?categoryid=63
