Hi,
I had the exactly same issue as Shindy and i also checked the OptiStruct from "Solver Interface" tab.
And i haven't downloaded Mechanical Solver file yet from website. I immediately installed Mechanical Solvers and tried again. But i couldn't run my analysis again. The warning was again "Could not find Compute Console Script. Please install Solvers".
All my files about hypermesh are located in the "C:\Program Files\Altair" so i also installed my Mechanical Solver to same adress. But like i said, still having same issue "Could not find Compute Console Script. Please install Solvers".
Can you help me solve this problem?
@Jason_Craanen, could you please elaborate on what you mean by "install the Mechanical Solvers with the Desktop.exe"? I am using a student version and had two separate '.exe' files for the solvers (hwSolvers2025_win64.exe) and for Hypermesh (hwDesktop2025_win64.exe).
Hello Shindy,
Did you install at the same time "mechanical solvers"?
Regards,
Marine Racollet
Hello Shindy,
Regards,
Marine Racollet
