1 - 3 of
31
Hi,
It is recommended to use simlab right from the beginning with CAD geometry.
Face mesh control with merged faces option would help you to avoid tiny elements in that region.
Switching to Hm is not good option.please refer attached screenshot for your reference.
Rahul R
Since simlab is the automated way of generating mesh. it is not possible to preview mesh before mesh.
You can pick desired face and mesh only that region ,instead of whole body using surface mesh.
After applying local mesh control and once meshing is done you can crosscheck mesh using transfer option.
Regards
Rahul R
