Boundary Conditions-Planar contraints
I am working on a component where I have to constrain one end of the model only in Rotational. . and those constraints should be locally defined( planar constrain). Pls find the attached image.
The black highlighted face area has to get constrained to that local plane only in rotational.
pls guide in this regard,
Thanks,
Nagaraj
Thank you Pranav,
I have done the same. And I have assigned the nodes of the face to the local system also.
But I am not happy with the modal displacements its showing.
Hence the query.
Thanks,
Nagaraj
Hi Nagaraj
Can you please share your model file.I will check and try
Also what type of Analysis are you doing?
Can we assign spc to a system? Is this new in current version?
Create systems and assign nodes to the local system. Constraining the nodes will constrain the nodes in the local system. This should work.
But the user is not really happy with the results.../emoticons/default_huh.png' title=':huh:'> So, giving it a try...
Hi Nagaraj
You can refer this attached video for creating a local system to your component.
Once you assign the local system to your component then you can create constrains by clicking on to Analysis > constrains
Select the nodes along the required area and tick on dof4, dof5, dof6 which constrains the degree of freedom only in Rotational axis.
Hope it is clear..
