🎉Community Raffle - Win $25
Join and Win
HM command recorder
User: "pohan"
Altair Community Member
Updated by pohan
Hello
 I tried to use the hm_command_recorder.tlc (please see attached file) file but it did no work because as the video it need the command.cmf file but as far as I know from version 14 this file is not exist. Could you please give me some suggestions.
1 - 12 of 121
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Which version of Hypermesh do you use?
    'command.cmf' is OLD release.
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    I don't think command recorder is anymore needed. For Altair Hypermesh 14 and above command.tcl saved in working directory (mostly in Documents) does the needed job.
    User: "pohan"
    OP
    Updated by pohan
    HI
    I use version 2017
    User: "pohan"
    OP
    Updated by pohan
    Hello
    Could u please tell me more about that! Does it means every command in HM saved after we save that file?
    User: "llyle_20499"
    Hello
    Hi,
    It keeps a track of all the operations you're doing in HM. It saves automatically in background.
    User: "pohan"
    OP
    Updated by pohan
    Thank you Livil Lyle
    In my opinion, sometimes if we want to focus on some specific commands may be command recorder is better.
    User: "tinh"
    Updated by tinh
    It is not a problem with me. I usually delete command.cmf before I focus on a certain command.
    the recorder is actually unnecessary
    if i want to track it, I will set a tracer
    User: "pohan"
    OP
    Updated by pohan
    Hello
    I create my first tcl/tk script file with the syntax like that
     *startnotehistorystate {Deleted Components} *createmark components 1 ' RW_left' ' RW_right' 'Compresseur' *clearmark components 1 *createmark components 1 ' RW_left' ' RW_right' 'Compresseur' *deletemark components 1 *endnotehistorystate {Deleted Components}
    in order to delete component ' RW_left' ' RW_right' 'Compresseur' in my model.
    But when I run the tcl/tk script file it did not work.
    Could you please give me some suggestions?
    Thanks
    User: "tinh"
    Updated by tinh
    Hi
    try removing space in front of comp names
    you have excessive createmark and clearmark commands at line 2 & 3, they are unnecessary.
    User: "pohan"
    OP
    Updated by pohan
    Hi
    Hi
    I tried but It said that
    invalid command name '*startnotehistorystate'
        while executing
    '*startnotehistorystate {Deleted Components}'
        (file 'D:/Dropbox/Lille/Altair/TCL/Hoan/command03_15_delcomp.tcl' line 1)
        invoked from within
    'source {D:/Dropbox/Lille/Altair/TCL/Hoan/command03_15_delcomp.tcl}'
        ('uplevel' body line 1)
        invoked from within
    'uplevel #0 'source {$file}''
        (procedure '::HM_Framework::p_FileLoad' line 68)
        invoked from within
    '::HM_Framework::p_FileLoad 24'
        (menu invoke)
    User: "llyle_20499"
    Hi Pohan,
    You don't need startnotehistorystate and end endnotehistorystate. All you have to do is:
     *createmark components 1 'RW_left' 'RW_right' 'Compresseur' *deletemark components 1
    User: "pohan"
    OP
    Updated by pohan
    Hi Tinh and Livil
    Thank you very much. It worked with two rows.
    I think  startnotehistorystate and end endnotehistorystate are for undo.
