🎉Community Raffle - Win $25
Join and Win
Problems with the order of nodes
User: "pohan"
Altair Community Member
Updated by pohan
Hello I tried to translate elements with options keep original component type and duplicate (please see the picture below)
But I dont know why the order of the node is changed.
Could you please explain me some solutions. I also attached the model file.
Thank you
1 - 21 of 211
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    What do you mean 'order of the node'?
    User: "pohan"
    OP
    Updated by pohan
    Hi I mean the order of the number of the nodes. Please see my picture two original nodes number is 371 and 497 but after the components are translated the numbers is 1022 and 1020 instead of 935 and 1043.
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    Do you have a particular purpose for the order of the nodes.
    You can always reorder the nodes in tools.
    Thankyou
    How do you calculate the numbers 935 & 1043?
    User: "pohan"
    OP
    Updated by pohan
    Hello,
    Thankyou
    Hello.
    Yes a have a particular purpose. Where can we find the reoder tool?
    Thanks
    User: "pohan"
    OP
    Updated by pohan
    Hi just know the number of nodes in one circle and after that I calculate base on the number of circles translated
    Normally , after translated the order is keep, but I dont know why in this case it does not work correctly.
    You can renumber nodes of one set, one component, assembly,... from a value. But I don't think you can control how the nodes will be numbered within this set, this component,... Try 'Tool' => 'renumber'. For post-processing reason you want control theses numbering?
    Instead of working directly with node numbering, you can work with sets for example.
    User: "pohan"
    OP
    Updated by pohan
    Thank you Dai
    I want to control the node's number because for each circle I will create one gruop set by TCL. So if I know the first and the end nodes of each circle I can create the group node easily
    But there's also another methode to create node sets. For example with 'by face', you need only ONE node & we do not care about numbering.
    Yes @Q.Nguyen-Dai is right.
    It will be easier to create node set by using 'by face' function
    Thankyou
    User: "pohan"
    OP
    Updated by pohan
    Hi with hypermesh it is easy but in TCL when I tried create set by face the command like that
    *setvalue sets id=8 ids={nodes 479-586}
    So it is necessary to control the order of node number
    User: "tinh"
    Updated by tinh
    use *createmark nodes 'by face' and get node ids first
    it's not good to program with detail value of node ids, everytime they should be arguments (variable) instead of values (const). in your code, 8, 479, 586 are const
    User: "pohan"
    OP
    Updated by pohan
    Hi Tinh
    Could you please explain me more about
    'use *createmark nodes 'by face' and get node ids first'
    I can not find *createmark nodes 'by face' on help!
    User: "tinh"
    Updated by tinh
    you don't need to mark it by face
    after duplicated elems, find nodes by *findmark command and provide that node list to set
    User: "pohan"
    OP
    Updated by pohan
    Thank you tinh
    In my case, I have to create one node set for each circle or half circle.
    Could you please give some explain for this case?
    User: "tinh"
    Updated by tinh
    before writing tcl, how will you do it in hm gui?
    User: "pohan"
    OP
    Updated by pohan
    Hi
    As your advice, before writing tcl I will create node sets by face. But I can not find the command to do this in TCL
    User: "tinh"
    Updated by tinh
    so *appendmark nodes 1 'by face'
    can do it
    User: "pohan"
    OP
    Updated by pohan
    Hi
    Thank you for helping me. I have just created my tcl file and it works.
    In my opinion if we can master how how the nodes will be numbered in HM it will be very helpful.
    User: "tinh"
    Updated by tinh
    i think node numbering when duplicate elems with n nodes will be: new_number = old_number+n
    But i am not sure, i just predict basing on programming flow.
    Hi
    Working directly with node/elems numbering maybe is not a good idea by the sense of numerical method.
    You have already some tools like set/group for this.
