Rotational velocity
Hi,
I want to simulate a fan rotation problem in radioss. I want the fan to be rotate in a particular rpm.
As I know with imposed displacement with XX,YY or ZZ direction we can input it. But where to set the rpm as per requirement.
Is there any options to define the rpm.
kindly suggest.
Hi,
the function can be constant or ramped up to the rad/s value calculated from RPM.
