How to exclude a part from an analysis
Hi to All,
I want to run an analysis on an assembly and I want to exclude a component from the analysis without deleting it from the assembly.
Is there any way to do this.
Globally speaking, is there any way to create multiple configurations, excluding specific parts, according the analysis I want to run.
Thank you for your response.
If you are using Radioss or optistruct as solvers then
Go to >Analysis>radioss> and select export options as displayed
Now swith off the component you want to exclude from the analysis and proceed.
Hi
On Export tab / Export Options
You select Export: Custom / Select entities
In Entity State browser you de-activate the comps you want to exclude from analysis
it will not be exported
Hi Tinh
Thank you so much for your help.
Have a nice day.
Hi Raviteja
Have a nice day.
Hi
