🎉Community Raffle - Win $25
Join and Win
*createstringarray
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I have written a TCL script that selects certain elements in my mesh. I want to have these elements put into a string array, so I can use this array to update a certain NASTRAN card, in comments, so I can use them later on in a different routine. The problem now, however, is whenever I try to use *createstringarray it gives back a 0 in the left corner.
The string is in a variable that needs to be substituted into *createstring array:
set elements {213 5342 53 213 642};
set $str [subst {\$BSURF 1 $elements}];
(Note that the BSURF is commented via $, hence the backslash)
*createstringarray 3 '\$beginbsurfs' $str '\$endbsurfs'
This following procedure returns a zero. What am I doing wrong?
Thank you for your help and time!
Jeffrey
1 - 5 of 51
    Altair Employee
    OP
    Hi Jeffrey,
    please try the the following in line 2
    set str [subst {\$BSURF 1 $elements}];
    Only access to a variable needs a '$', not at creation time...
    You can insert a check after this line:
    tk_messageBox -message 'String : $str'
    Here you need the '$'
    Regards,
    Mario
    Altair Employee
    OP
    Hello Mario,
    The '$' was a typo from my side. It appears that the $elements variable that is created in HyperMesh causes an error, while using a user created variable with set numbers seem to work perfectly:
    Works. The following does not:
    $elems is a list created in HyperMesh by means of a TCL script. This is just an ordinary but lengthy list.
    set str [subst {\$BSURF 1 $elems}];
    Maybe the error window output gives more insight of what the problem is?
    0
    while executing
    '*createstringarray 3 '\$beginbsurfs' $str '\$endbsurfs''
    ('uplevel' body line 1)
    invoked from within
    'uplevel #0 {*createstringarray 3 '\$beginbsurfs' $str '\$endbsurfs'}'
    invoked from within
    'interp eval $::tkcon::OPT(exec) $args'
    (procedure '::tkcon::EvalSlave' line 2)
    invoked from within
    'EvalAttached $cmd'
    Thanks for your help and time.
    Jeffrey
    Altair Employee
    OP
    Hi,
    sry, can't detect any error. For me it works for elements or elems.
    Please check whats inside of $elems
    set elems {213 5342 53 213 642};
    tk_messageBox -message 'Elementlist : $elems'
    Normaly TCL strings are not limited, but maybe *createstringarray has a limit in string lenght. Please check it too.
    Regards,
    Mario
    Altair Employee
    OP
    Hello Mario,
    I think the string length is limited. I've created a workaround, grouping ranges of values together. The string created is far smaller than the original string and it does create the string via this method.
    Nonetheless, I've checked the items inside $elems and the information is just numbers, element ID numbers.
    How and where could I check the maximum length of *createstringarray?
    Thank you,
    Jeffrey
    Altair Employee
    OP
    Hi Jeffrey,
    i don't know a answer, so it is better to contact the Altair hotline.
    Regards,
    Mario
